LT80 Bottom End Rebuild
Old Jul 12, 2006 | 11:07 PM
freightrain's Avatar
Default LT80 Bottom End Rebuild
It looks like I'm going to attempt a bottom end rebuild due to excessive play in the rod. I've got the manual and it seems pretty straightforward, but I may need to bring it into the shop to have the crank pressed back in. At least I don't have to mess with any tranny gears. Has anyone done this? Any tips? Should I get a full Hot Rod kit, or can I get away with just the crank bearings, seals, rod bearings, and thrust washers? Any advice is appreciated.
Mike
Old Jul 13, 2006 | 11:11 AM
LT80's Avatar
LT80 Expert
I'd get a new crank.
By the time they rebuild the old crank, a new one isn't that much more. Trueness is another reason. Getting them straight again can be very hard.
FYI: the crank is not pressed in. I use heat and have everything slide together nice and easy.[img]i/expressions/face-icon-small-smile.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
badgerboy1
Sep 26, 2017 06:11 PM
Beeline08
Nov 11, 2016 04:00 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
