SP 700 Carb what's happening
Old Jul 15, 2006 | 09:10 PM
bigdaddyisu's Avatar
Default SP 700 Carb what's happening
I've got an 2004.5 carbed 700. Lately when I ride on a long straightaway it kind of dies out once it hits 45 on the speedometer. It used to run up to 55-60 range. It takes off fine full throttle from a complete stop but once it hits 45 it's like the machine all of a sudden has a speed limiter on it.
Any ideas what's going on with my machine? Clutch, carb, what should I check first?
Old Jul 15, 2006 | 09:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if its running fine and has no power loss or bogging i would start at the clutchs maybe the spring in the secondary is out or broke or something. just my 2 cents where i would start
Old Jul 15, 2006 | 10:03 PM
Thanks, I was thinking the clutch was my first check since there's no power loss from 0-45mph.
Old Jul 16, 2006 | 01:47 PM
SPORTSMAN70003's Avatar
Also check your limiter nut on your primary clutch. I have heard of a few that backs off a little and you lose topend speed. It don't let the primary sheaves close all the way. If you look here its #8 right behind the primary spring.
Old Jul 16, 2006 | 05:20 PM
UTU's Avatar
UTU
Thats what my 700 was doing and THATS what the problem was. The Plastic collar had backed off it tightned up about 3-4 complete turns and WAL-LAH I had my top speed back! Good Luck,Take Care!!
Jmuddin284
Jan 19, 2026 07:16 AM
GregM
Mar 6, 2018 06:53 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
