sportsman : 4X4 or speedometer not working
i just bought a 1999 335 sportsman 4x4 the atv seems to be in overall good
condition.my problem is the speedometer and the 4x4 dont work at all.what
should i be checking to find out what my problem is?any suggestions would be greatly appriciated!
i just installed a new battery and still the AWD or speedo dont work.
should a light come on as soon as i push the AWD button to let me know
that its in AWD?or will it just come on when the front tires kick in? also
i took the cover off of the speedo and its analog so i dont think it has anything
to do with the AWD working.if ANYONE can tell me what i should check on both
of these problems please help me out. I am open to any and all help.
thanks in advance
thanks in advance
If you have the black speedo with an analog odometer, then the 2 problems you have are seperate issues. If the speedo has a digital odometer, then they are related. Does the AWD light come on at the switch?
yes i have the analog type speedometer.the AWD light does NOT come on at all.it has the red push button type,i have heard that these switches are bad for corroding.can i take it apart and clean the contacts?
You could, but it can be a number of things. Does the nuetral/reverse light work correctly? Does the nuetral stay on all the time? Check power to the switch. If you are getting no power to it, then it will rule it out. Start with this and let us know
whitty
67
Feb 24, 2021 02:52 PM
jayking232003
Dec 4, 2019 09:38 AM
chuck1177
Jun 30, 2015 09:52 AM
