Transmission problem I think?
Old Jul 27, 2006 | 11:42 AM
bamurf80's Avatar
Default Transmission problem I think?
I need some help. This might be a little hard to explain but here it goes. I have a 2002 trailblazer and on take off it and at slow speeds it makes a loud clicking sound and I can't figure out what it is I dont know if it is something in the transmission or if maybe the sprockets are worn and slipping a tooth. Any help would be great
Thanks,
Bamurf80
Old Jul 27, 2006 | 12:53 PM
scramblerguy15's Avatar
This might sound stupid but it could be your axle slipping in your hubs, but it would make the noise your talking about at high speeds also. My second guess would be you chain slipping on sprokets, check to see if any rollers on your chain are broke off. If its not any of that It could be your transmission, but I would not expect that in a 2002.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 27, 2006 | 04:31 PM
madmatt1971's Avatar
It may just be you clutch weights clunking when they engage. My SP 700 clunks when I start to accelerate.
Old Jul 27, 2006 | 05:02 PM
scootergptx's Avatar
Supersock
Hired Gun!
If it's like my 03, it wasn't a consistent click. Check all sprockets and chains, and they were fine. Before I had a real good chance to look at it, one of my nephews took it out. Now I have no reverse. [img]i/expressions/face-icon-small-mad.gif[/img]
Old Jul 27, 2006 | 05:29 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
chances are its the spokets or chain. make sure the chain tight enough and isnt wanting to jump or make sure the chain isnt kinked somewhere. start w/ that first to rule it out.
Old Jul 27, 2006 | 05:33 PM
Supersock
Hired Gun!
If I remember right, I think that was pretty common. Think it was something that had to do with the ujoints or linkage.
Old Jul 27, 2006 | 06:14 PM
Kerbbirds's Avatar
check the essentrics, where you tighten the chains. I had a bearing go out of the one right in front of the motor,it made a clicking sound for a while then got alot worse.
Old Jul 27, 2006 | 07:00 PM
ftwflh's Avatar
If the drive chain and sprockets are good I would say the chain in the tranny is bad.
Old Jul 27, 2006 | 11:01 PM
2manytoys's Avatar
Sounds like chain rubbing the bottom of swingarm on take off and at slow speeds. Or the silent chain in the tranny. Check chain tension.
Old Jul 27, 2006 | 11:11 PM
tblazer's Avatar
Had the exact same problem with my 2001. It always happened on takeoff and when the rear tires came under a great amount of pressure and it would sit there and click and clunk. Ended up being worn gears in the transmission.
greg74
Sep 10, 2019 03:03 PM
Captjay
Jul 23, 2015 12:33 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
bikedad3
Jul 2, 2015 02:15 AM
