Yet another warrior problem
Old Aug 1, 2006 | 09:47 PM
YamahaRider8998's Avatar
Default Yet another warrior problem
ok this is the deal, im tryin to sell my warrior cause its nothin but headaches, the only problem is that over the past month its been getting more and more harder to start. Wat happens is i turn everything on and press the starter button, all i hear is the low click from the mess of electrical things under the rear fender. at first it started after pressing the button like five times without anything happening now it takes closer to twenty. Also when it does start it starts right up without trying. I tried it with holding in the clutch and without, same difference. I also tried a new sparkplug helped make it start even better when it did start but nothin really. I recently got the starter relay and coil or soemthin fixed and the starter wroked fine. Could this be a low battery or something worse like a bad starter or starter clutch. Or is it the button maybe. I need help quick so i can fix it asap.
steve
Old Aug 1, 2006 | 09:55 PM
GlennJ's Avatar
I had a really similar issue with my Wolverine. Long story, short, it was the brushes. Try tapping your starter with the handle end of a screw driver. If it starts after that, it's the brushes.
I put in new brushes, lightly sanded the commuter, cleaned out the grooves and it works like a champ now.
Old Aug 1, 2006 | 11:08 PM
how much are brushes roughly and where exactly are they and what do they do, in the starter itself or attached or somethin, and where is the starter on the quad. thanx for the response
steve
Old Aug 1, 2006 | 11:11 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
next time it does it.. push the quad forward with the clutch pulled( just a few feet)
Old Aug 1, 2006 | 11:30 PM
if i may ask, why
Old Aug 2, 2006 | 02:37 AM
2000IAWarrior's Avatar
sounds like the starter..
pull it off once.. only 2 bolts and then the power wire.... and then pull the 2 bolts out that hold it togehter and see what it looks like.. or smells like..
Old Aug 2, 2006 | 08:39 AM
GlennJ's Avatar
The brushes send the current to the motor. When they're worn out of spec, they can't send the proper amount of current and won't turn the starter over. In addition, when they're worn, the old material tends to clog the commutor.
How much are they? Depends. I ordered a set for $14 or so. I had to solder one to the post on the starter. You may want to check with your dealer and see what they offer.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
