Rubicon Tire
Old Aug 2, 2006 | 06:16 PM
sporter's Avatar
Default Rubicon Tire
I removed a 3/8" piece of a stick from my ITP 589 tire (I assume it's 6 ply) it went in at an angle and the tire does not appear to be leaking but now I'll be concerned it will go flat at the worst possible time. What's the best repair? I've been reluctant to "Slime" the tires because I don't know what that stuff will do to my aluminum wheels. Could I "slime" one tire with no ill effects? Suggestions, please.
Old Aug 2, 2006 | 06:33 PM
rubicondude's Avatar
unfortunately I do not have an answer for your question, but I was just wondering what year rubicon you have and if you have any mods on it.
Old Aug 2, 2006 | 07:31 PM
500rubicon's Avatar
The best thing to do is to have plugs with you while riding to do a quick fix, then take the tire to a garage and see if they can have it vulcanized(thinks thats what it called), if not that they clear off a spot around the hole then melt some rubber to fill in the hole.
Old Aug 2, 2006 | 08:35 PM
sporter's Avatar
Dude,
It's an '05, no mods except for the ITP tires and wheels.
500,
I forgot to mention the stick was in the sidewall.
Thanks for the reply.
Old Aug 2, 2006 | 08:42 PM
squeege's Avatar
I have seen a metal screw hold air in a tire for like 2 weeks.....anybody try a tire plug kit?
Old Aug 2, 2006 | 11:23 PM
Rinman's Avatar
I have 3 plugs in the side wall of one of my rear tires now. The hole was about an inch long. The have been in there about 4 months with no leaks. Plugs work fantastic, even in a side wall. I carry 4 packs and slime with me now when ever I ride. As far as slime goes, it works great. But I haven't had the tire changed since adding it. When I do I'm sure the person changing it will be pissed. It works good but makes a sticky mess.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
