Axel Stress
Old Aug 4, 2006 | 01:24 AM
BigPolaris01's Avatar
Default Axel Stress
I have a 2000 honda Foreman.. Was wanting to No how much More Stress would be on the Axels if I put a 2 Inch Lift On and some 27 maxxis Mud Bugs.. I am mostly talking about the Front Axel.. That Straigh Axel In the rear I no will Hold those Mud Bugs.. If you have Any Sugestions On lift type Please let me no..
Old Aug 4, 2006 | 11:22 AM
action450s's Avatar
Default Axel Stress
You dont need lift to clear 27's on the 450, dont know if you do if your bike is a Forman 400. Lift will put more strain on the front CV's especially with that tire, its one of the heaviest on the market out of the box, and worse when its fully loaded with bog as it scoops more then most other tires.
Since every lift I've seen is just a shock spacer (forces the suspension towards full extension) its not really worth it. I'd like to see a proper kit like you can get for trucks and IRS bikes that keep the geometry close to stock. According to an email I got from gorilla axle, they are developing such a kit for the Forman.
Old Aug 4, 2006 | 09:09 PM
Default Axel Stress
I No I don't need A lift to Clear 27's But I was just wanting to get a Little more Ground Clearince... Did they Ever say when that Lift Would Be avalable to Buy... If you Could keep me Informed on That Lift..
Old Aug 4, 2006 | 11:45 PM
2manytoys's Avatar
Default Axel Stress
A lift will do nothing for ground clearance in the rear and the rear is where you need it most. The front is not much of an issue. If you shift weight back it will get the front up more. I think you will lose alot of power if you put 27" tires on. You need all the power you can get when playing in the mud. Nothing worse than playing in the mud and you cant even spin the tires because they are too big.
toonces
Oct 16, 2019 12:11 PM
Biggieshortie89
May 26, 2015 08:01 AM
dstevens
Feb 7, 2001 10:51 PM
DrRod
Jun 13, 2000 12:51 PM
sAyIt_fmf
Apr 7, 2000 09:16 AM
