Help warrior problems????
Old Aug 21, 2006 | 07:38 PM
99warrior350's Avatar
Default Help warrior problems????
Hello, i need help. The red reverse light will not go off on my warrior, The reverse lever is pushed foward all the way. But the red light is still on. when i rev the engine the light gets brighter. please help i have no clue what this means.
Old Aug 21, 2006 | 07:42 PM
JLsparky7's Avatar
Check all your connections, its probably a short in the wiring somwhere. Maybe you need a new fuse.
Old Aug 21, 2006 | 10:29 PM
recon99's Avatar
How long has it been doing it? When did it start? Any additional info, like if it happened after you washed it, could help find an answer.
Old Aug 22, 2006 | 03:04 AM
GraphiteDak's Avatar
Well, if the ATV is still working ok in forward and reverse when you move the lever, it's simply the switch sticking or shorted on the reverse linkage.
In actuality, it wont hurt a thing except leave the light on.
It getting brighter is normal when the altenator generates more voltage off of idle.
Old Aug 28, 2006 | 08:38 PM
It started when I was riding and I put it in reverse then it never went off not even when i switch to neutral. And now I have to pull the clutch in every time i start it in nuetral. Do you know where the fuse, switch, or wire is that needs to be replased. thanks.
Old Aug 29, 2006 | 12:09 AM
recon99's Avatar
Most likely your problem is a shorted wire somewhere, not the reverse sensor itself. The reverse sensor is on the left side of the engine above the sprocket, it looks sort of like a bolt with a wire connected in the middle. To check the sensor, simply unplug the wire, unscrew the sensor with a socket wrench, and inspect it. The end of it should be spring loaded, and easily push in and pop back out. Just be careful when you put it back in, don't do like I did and overtighten it, they are VERY soft and easy to break, and cost like 20-30 bucks if you have to replace it.
Old Aug 29, 2006 | 02:23 PM
Mine is very loose and it has silicon all around it. i think i might need a new one. Is it called a reverse sensor? thanks.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
