sportsman 400 running problem
Old Sep 18, 2006 | 06:59 PM
firechicken's Avatar
Default sportsman 400 running problem
I just bought a 2001 Sportsman 400 that is not running. I got it running, but it pops through the carb. and actually spits the gas out of the carb. It acts like the exhaust is coming through the carb. I've checked the compression, valves, and timing. Everything checks to be correct. Today, I pulled the coil wire off to check for fire. I also put a plug wire in the wire and grounded it and spun the motor over only to have it fire once and then quit with the motor still spinning over. Every time you stop spinning it over and try to start it again, the motor does the same thing. Has anyone encountered this problem before? Any helpful help would be greatly appreciated.
Thanks
Old Sep 18, 2006 | 07:32 PM
ttt
Old Sep 18, 2006 | 08:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
seems i read some where on here a while go about that. do a serch and see what you come up with. maybe something to do w/ a sheared key way on the crank i think. not sure.
skittero
35
Mar 1, 2019 12:39 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
wildbill59
Jun 9, 2015 02:28 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
