What will it hurt?
Old Sep 27, 2006 | 09:15 AM
jbull's Avatar
Default What will it hurt?
I know how to disconnect the automatic oil injector on my LT80 thanks to posts and replies on the forum. What I was wondering was will it hurt anything to just leave it hooked up and run premix instead? I know the cam/gear part is normally removed inside the engine side cover, but will it hurt to just leave it there and run the quad?
Old Sep 27, 2006 | 10:35 AM
LT80's Avatar
LT80 Expert
It's like running any gear/pump dry...Future problem IMO.
Old Sep 27, 2006 | 04:52 PM
jbull's Avatar
This spawns another question.... Can I simply remove the gear but still leave the pump and line running to the carb in place? Is it necessary to cut off the line and plug it or can it be left alone? Could I just remove the oil tank and cap off the fitting at the pump then? Thanks.
Jeff
Old Sep 27, 2006 | 04:57 PM
squeege's Avatar
I would plug the carb line but still leave the pump in(remove gear)....remove the oil tank
Old Sep 27, 2006 | 05:02 PM
Hymis's Avatar
It's so easy to remove the whole thing. Pull the tank line etc. Cut the line at the carb and get a vaccum line plug from any automotive parts store and cap it right over the metal fitting coming off the carb. Call Trinity and buy a $ 8.95 block off plate for the clutch case. Voilla! Dishes are done.
Old Sep 27, 2006 | 10:12 PM
squeege's Avatar
ohh yeahh! and don't forget to change the throttle cable!
Old Sep 28, 2006 | 09:15 AM
jbull's Avatar
Ummm... change the throttle cable? Where did that come from? Did I miss something there?
Old Sep 28, 2006 | 09:23 AM
squeege's Avatar
On mine....the throttle cable Y's off and most people switch To a single cable for the carb only
Old Sep 28, 2006 | 12:17 PM
Hymis's Avatar
My throttle cable doesnt Y are you sure your talking about the lt80?
See this............ Diagram
Old Sep 28, 2006 | 12:51 PM
squeege's Avatar
In that case you'll be fine....
shimanok2
Jan 29, 2016 07:37 PM
traumajunkie
Sep 7, 2015 08:39 PM
jeepin
Dec 30, 2000 03:16 AM
