Att: LT80 ( Jack Moore )
Old Oct 4, 2006 | 02:34 PM
Dilwert's Avatar
Default Att: LT80 ( Jack Moore )
Lt80 .. can you email me the directions on how to remove the 2 clutch rollers and any other mods you might have for a 95 LT80 please ?
Email to : RMartinez5@houston.rr.com
Roy
Old Oct 4, 2006 | 03:06 PM
Hymis's Avatar
Here is a diagram for the Tranny. Tranny 1
Tranny 2
Old Oct 4, 2006 | 08:40 PM
Dilwert's Avatar
I have seen these before but I don't understand what to remove. Can you point out what two rollers can be removed?
Old Oct 5, 2006 | 02:13 AM
Rudedog's Avatar
In drawing tranny No. #1, It's item number #5. Stock there are (6) rollers. Remove 2. Make sure their opposite of each other IE: 12 & 6 O'clock..., 3 & 9 Etc.
Rude Dog
Old Oct 5, 2006 | 12:23 PM
Dilwert's Avatar
Oh I see now ... much better explanation... thanks for the tip. Do you know what is the exhaust mod tip? Remove some air restrictor from the exhaust ?
Old Oct 5, 2006 | 12:36 PM
Hymis's Avatar
Between the exhaust port on the head and the muffler there is a restrictor plate. Also, you have have a carb restrictor. Brass dealio in the carb. I dont have much knowledge about it, maybe somebody will chime in on this.
Old Oct 5, 2006 | 12:40 PM
Hymis's Avatar
Muffler Diagram
I think its Item # 17
Old Oct 5, 2006 | 05:00 PM
Rudedog's Avatar
The carb restrictor was factory installed and found under the carb top. Un-screw the carb top and see if you see a large round block piece. If there it's between the carb top and the carb slide. If not it has already been removed.
Rude Dog
Old Dec 4, 2022 | 03:58 PM
cschneider's Avatar
Default Can you please email me to schneiderchad@hotmail.com
Roy
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
