rubber
Old Dec 6, 2000 | 08:16 PM
redyam350's Avatar
My rubber on top of the carb where the throttle cable enters is cracking will it cause an air leak later down the road.
Also where could i get new ones since they took the tors off with a twist throttle
Old Dec 7, 2000 | 01:29 AM
redyam350's Avatar
does anybody know
Old Dec 7, 2000 | 10:12 AM
sAyIt_fmf's Avatar
If the TORS was removed...It is probably a motion pro twist..or some other aftermarket company...
You will probably have to call them and see about replacement parts... If all else fails...a bit of flexible RTV sealant should keep the moisture out.
Another idea is heat shrink with the sealant that kind of oozes out when it is heated.
ReconBayou
Oct 16, 2019 02:24 AM
franklyme
Oct 21, 2016 07:18 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
lancemll88
Sep 6, 2015 03:03 AM
lancemll88
Sep 5, 2015 03:16 AM
