Outty 800 top speed 70 MPH--Why?
I have 8 hours on my machine and a stock King Quad out did my machine on top end. He can't touch me out of corners but on the straights he can out run me. Seemed like there is a rev limiter or something. Possibly the way the dealer set it up, gearing?
The King Quad has a timing retard/defueling feature built into the ECM up to 2000 RPM but on top end the King Quad will run with anything curently on the market.
I think you should have your machined checked out. It should not serge or be hitting the rev limmiter at 70mph. I do not know of any others that are doing that. I do know there are several different limp modes that can cause a reduction in you rev limmiter all different amounts of limmiting RPMs dependent on the problem. If I had my book handy I would give you some examples but its at the shop. What RPM are you hitting when it starts kicking down?
Originally posted by: BBR650
your outty has a built in break in cycle in the computer, you will get a 5% increase after 10hrs and then another 15% after 20-25 hrs. this is your problem.
I guess I just want to if there is anything to do with break in settings. Some one must know for sure if this is true or not. Also I guess I could have been doing more than 7000 rpms I was paying more attention to my speed jumping back and forth from 69 to 70.
