Outty 800 top speed 70 MPH--Why?
Old Oct 14, 2006 | 07:32 PM
drwindmill's Avatar
Default Outty 800 top speed 70 MPH--Why?
I have 8 hours on my machine and a stock King Quad out did my machine on top end. He can't touch me out of corners but on the straights he can out run me. Seemed like there is a rev limiter or something. Possibly the way the dealer set it up, gearing?
Old Oct 14, 2006 | 09:58 PM
hikuntryslim's Avatar
maybe you got a lemon ...........???
Old Oct 15, 2006 | 02:24 AM
drwindmill's Avatar
Thanks for your help.
Old Oct 15, 2006 | 09:22 PM
1882's Avatar
Runs a Full 730 Race Build!
The King Quad has a timing retard/defueling feature built into the ECM up to 2000 RPM but on top end the King Quad will run with anything curently on the market.
Old Oct 16, 2006 | 12:29 AM
cc1999's Avatar
I think you should have your machined checked out. It should not serge or be hitting the rev limmiter at 70mph. I do not know of any others that are doing that. I do know there are several different limp modes that can cause a reduction in you rev limmiter all different amounts of limmiting RPMs dependent on the problem. If I had my book handy I would give you some examples but its at the shop. What RPM are you hitting when it starts kicking down?
Old Oct 16, 2006 | 01:02 AM
BBR650's Avatar
Is always changing bikes.
your outty has a built in break in cycle in the computer, you will get a 5% increase after 10hrs and then another 15% after 20-25 hrs. this is your problem.
Old Oct 16, 2006 | 01:05 AM
drwindmill's Avatar
I believe I was in the 7000's. I am sure the machine actually was cutting out. My Outty has tremendous bottom end power, no prob there at all, that's the weird part.
Old Oct 16, 2006 | 01:07 AM
drwindmill's Avatar
Everyone else says there is no break in setting. How do you know this?
Old Oct 16, 2006 | 01:13 AM
travelor's Avatar
Mine got faster with over 100 miles. The rev limitor shouldn't affect you until over 8000 rpm.
Old Oct 16, 2006 | 01:18 AM
drwindmill's Avatar
I guess I just want to if there is anything to do with break in settings. Some one must know for sure if this is true or not. Also I guess I could have been doing more than 7000 rpms I was paying more attention to my speed jumping back and forth from 69 to 70.
