recon problems
Old Oct 23, 2006 | 09:50 PM
BIGREDBOGGER's Avatar
Default recon problems
i have a 97 recon and everytime i go through a ditch, pop a wheelie, or go in water around the footpeg it dies and is hard to start back up but if i shake it side to side it will start right up. anyone kno how to fix this?
Old Oct 23, 2006 | 11:09 PM
jonnyboy5662's Avatar
may be the float is getting stuck... but that wouldnt explain the water up to the foot pegs deal. Are you sure there are no cracks/holes in the cases?
Old Oct 23, 2006 | 11:22 PM
yea its done it since it was brand new
Old Oct 23, 2006 | 11:37 PM
so have you checked the carb?
Old Oct 24, 2006 | 01:04 PM
bombrider04's Avatar
take your carb apart and clean out the jets making sure you can see light through the holes, change your oil and make sure you have no water in it, spark plug, and make sure your valve clearence is fine...I just added a few other maintanance things but the carb is most likely clogged so clean the jets out.
Firefighter400
Oct 8, 2022 06:38 PM
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
hondarider1234
Jul 21, 2015 11:53 PM
MNatv89
Jul 7, 2015 11:36 AM
