Biggest Tires??
I was just wondering what the biggset tires are I can fit on my 2005 Brute Force 750i? Will I have to install a lift kit if I go with 28 inch Swamp Lites? And will my speedo be off? If so how would I fix the seedo?
Thanks.
Thanks.
i have a 650i. i am currently running 28' outlaws and they fit fine as far as clearence for how tall they are. where i had the problem is they were to wide for the rear right side. they hit my gas tank, barely. the cheap solution i came up with was to stick 2 washers between the hub and rim on that side and run like 12 pounds of air in them, which also adds to ground clearance. this has worked well for me so far.
