Biggest Tires??
Old Oct 26, 2006 | 11:25 PM
JMF750i's Avatar
Default Biggest Tires??
I was just wondering what the biggset tires are I can fit on my 2005 Brute Force 750i? Will I have to install a lift kit if I go with 28 inch Swamp Lites? And will my speedo be off? If so how would I fix the seedo?
Thanks.
Old Oct 27, 2006 | 09:12 PM
BigDog800EFI's Avatar
28" tires should fit. And as far as the speedo goes they are not very accurate anyways so I wouldn't worry about it.
Old Oct 27, 2006 | 09:23 PM
imstuck's Avatar
with aftermarket wheels 30in tires will fit with no mods 28in no problem on aftermarket wheels
Old Oct 28, 2006 | 09:05 AM
JMF750i's Avatar
THANKS GUYS.
Old Oct 29, 2006 | 09:04 PM
montyh's Avatar
my brute speedo is more accurate (within 1mph) with 27s that it was with stock 25s.
monty
Old Mar 15, 2007 | 02:50 PM
devinbright's Avatar
i have a 650i. i am currently running 28' outlaws and they fit fine as far as clearence for how tall they are. where i had the problem is they were to wide for the rear right side. they hit my gas tank, barely. the cheap solution i came up with was to stick 2 washers between the hub and rim on that side and run like 12 pounds of air in them, which also adds to ground clearance. this has worked well for me so far.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
highwayman
Sep 19, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
