Limmeted Slip
Old Dec 8, 2000 | 01:06 AM
StitchZR2's Avatar
Sorry about my spelling very tired
Anyway im having a hard time telling my freind that the Cat 500 front end 2001 model is better than the 450ES 2000 model. Please help...
Old Dec 8, 2000 | 05:20 AM
Diogenes's Avatar
It ain't.
Both are limited slip differentials of similar function, if not similar construction, I think, "reviews" and advertising hype to the contrary.
Diogenes
Old Dec 8, 2000 | 01:41 PM
N1TE0WL's Avatar
The limited slip on the cat may not be a whole lot better, but it is better. As for the construction they are completely different.
Old Dec 8, 2000 | 02:57 PM
lrichard's Avatar
I have a brother that has a 2000 model 500 Cat, his next door neighbor has a 2000 model Honda 450ES. They tied both to a tree on flat ground, the Cat made 4 even holes with all 4 tires spinning. The Honda made three holes with only three wheels spinning. They tried it again tieing both of them to a truck different type of ground but level, same results as the tree. There must be some kind of difference. The Cat had 27x12x12 Vamps all the way around, and the Honda had 27x12x9.5 Vamps in front and 27x12x12 Vamps in the rear.
Old Dec 8, 2000 | 07:37 PM
BONER's Avatar
This is what I found in the Tech Connection.
Name: David Roccaforte
Email: dave_roccaforte@asl-tk.com
I'm going to use a front limited-slip differential for the rear drive of a 70-hp, 30-lb./ft. rear-wheel-drive car, approximately 500 lbs. What ATV diff offers the largest amount of torque transfer? Most I've seen are around 30%. Would you recommend a cone or friction setup?
Yes, this is another one of those design competition questions. I would really appreciate your input. Just so you know that I read previous questions, I am going to try and locate the April '98 copy of DIRT WHEELS.
ATV: Arctic Cat Bearcat 454 4x4
Category: Conversion/Project Quads
Date: 30-Aug-99
Ref#: 7035
David,
The all-metal "ratcheting cone" as used in the Suzuki 500 and the Arctic Cats is superior to the wet multi-plate setup, 50% vs. 30% "torque bias."
BTW-- The all Yamamha, All Kawasaki, and Honda 4wds (except the Rancher and Rubicon) use the Multi-plate setup.
Old Dec 8, 2000 | 11:11 PM
JKB's Avatar
JKB
Hey boner, good info. Its better for sure, Enough said!
Cheers Jim
Jeff Roper
Feb 1, 2022 11:48 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
