2001 scrambler 500 4x4 AWD problem
Old Oct 29, 2006 | 10:01 PM
TWM111261's Avatar
Default 2001 scrambler 500 4x4 AWD problem
I have a intermittant problem with the AWD system ingaging on my Scrambler.
It sometimes stalls when put in reverse unless the override switch is held and
the awd does not always work.
When new it was returned same day for warranty with the same problem and
a switch was replaced and im not sure what it was.
It has been ok for the last 5 years.
Any one have any ideas ?
Thanks
Tom
Old Oct 29, 2006 | 10:30 PM
ftwflh's Avatar
You have a reverse limiter going bad.You can bypass it by unplugging the black wire coming out of the box.
Old Oct 30, 2006 | 09:19 AM
magna29's Avatar
If your speedometer is acting weird at all, its the speed sensor on the front right hub. If not then ftwflh has probably got it.
Old Oct 30, 2006 | 09:45 AM
TWM111261's Avatar
Thanks for the help but what black box ?
Old Oct 30, 2006 | 09:47 AM
TWM111261's Avatar
There is no speedometer. Is there still a speed sensor?
I have had both hubs apart and don't remember seeing
any sensor.
Thanks for the reply
Old Oct 30, 2006 | 10:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
there isnt one on your bike.
Old Oct 30, 2006 | 10:43 AM
magna29's Avatar
My bad, didnt see you have a scrambler! Sorry.
Old Oct 30, 2006 | 11:19 AM
TLC's Avatar
TLC
any sensor.
I ride with a(Canadian version) 2000 500 scrambler and it has the same speedometer and has the sensor on right front wheel as I do. The sensor on the right front wheel is called a "Hall Effect" mine does not work but it only works the speedo's speed needle, trip meter and odometer, only the hour meter works without it.
It does not effect the running of my bike in anyway so I dought thats your problem.
I just noticed,but I guess in the States a Speedo is a option on a Scrambler. That weird because on a Sportsman 500 a speedometer is required for the operation of the AWD system.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Jun 16, 2016 09:07 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 13, 2015 05:11 PM
Chocobamofo
Jul 10, 2015 07:46 PM
