polaris 700 won't start!
Old Oct 30, 2006 | 05:27 PM
wyant007's Avatar
Default polaris 700 won't start!
I have this used 2002 polaris sportsman 700 and when it runs completely out of gas in the tank on position. It will not start when i put the reserve on or after i fill the tank up. It is as if it is vapor locked or something. It doesn't do it all the time but about every fourth time. I try to keep gas in it, but the wife and kids all ride and it's hard to watch the tank level. The only way i can get it to start is to hit it with a lot of starting fluid. This can't be good for it and can't be normal. Does anyone have any ideas???????
Old Oct 30, 2006 | 06:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you see if when you put it on res. if its geeeting gas on maybe the petcock is bad. maybe the vacume to the fuel pump or the diapham is bad.
Old Oct 31, 2006 | 08:18 PM
wyant007's Avatar
I don't want to sound dumb buuuuuttttt, How can you tell if it IS getting gas and what is this petcock and where is it? Do you know of any troubleshooting ideas to reduce the variables?
Old Oct 31, 2006 | 09:46 PM
la90043's Avatar
FOLLOW THE FUEL LINE FROM THE GASOLINE TANK UNTIL YOU RUN INTO THE FUEL FILTER. THE FUEL FILTER IS A PLASTIC ROUND CYLINDER TYPE THING WHICH IS USUALLY WHITE IN COLOR WHEN NEW. DISCONNECT THAT AND PULL IT OUT OF THE FUEL LINE. REPLACE IT WITH A NEW ONE. IF PROBLEM PERSIST. TAKE OUT FUEL PUMP AND REBUILD IT. THE FUEL PUMP IS THE ROUND OR PENTAGON METAL SHAPE THING THAT IS ALONG THE FUEL LINES. IF PROBLEM STILL PERSIST AFTER THAT. TAKE OUT CARBURETOR AND REBUILD THAT. THAT SHALL TAKE CARE OF ALL OF YOUR PROBLEM AS DESCRIBED IN YOUR POST. YOU HAVE A FUEL DELIVERY PROBLEM
Old Oct 31, 2006 | 09:51 PM
la90043's Avatar
about the petcock.............thats the thing you move for fuel "on" for fuel "off" and for fuel "reserve". it is also called fuel valve etc etc etc. that sometimes can go bad too...........that will also give you a fuel delivery problem.........
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
1000gade
May 27, 2015 12:37 PM
