ATV Problems
Old Oct 31, 2006 | 03:08 PM
Jwthv00's Avatar
Default ATV Problems
I have a 1991 Honda Fourtrax 300. My problem is when i hook the positive and negitive to the battery with everything turned off my engine starts. Im wondering if i my starter is out or if i just have a strong ground somewhere. If anyone has any suggestions or has had this same problem let me know what you think i need to do.
Old Oct 31, 2006 | 03:17 PM
bombrider04's Avatar
hmm thats a first I have ever heard of that I would check all of the wiring and make sure everything is connected correctly...do they have keys in the 1991's or no I would check every wiring thing over it seems like the power is going directly to the starter
Old Oct 31, 2006 | 03:23 PM
Jwthv00's Avatar
Yes the 91 does come with a key switch. Do you think it might be a wire that is grounded or shorted.
Old Oct 31, 2006 | 04:06 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
It's Haloween..........your bike is posessed!
Old Oct 31, 2006 | 04:30 PM
Jwthv00's Avatar
Question on the back of the 4 wheeler by the battery the positive goes to a relay swtich correct. Does that relay switches negative go to the battery to ground the switch.
Old Oct 31, 2006 | 04:46 PM
Yes the pos goes to the starter relay I believe and then it should hook up directly to the starter...Well when it is turning on is the key in the quad at all or no and are any of the controls on the on position.
Old Nov 1, 2006 | 04:40 PM
quicksilver's Avatar
there should be 2 small wires hooking up to that starter relay also, unplug both small wires and recheck. if it still cranks right away, you starter relay is faulty.
if it doesnt crank by itself anymore, you have a short to ground or short to power in those small wires, basically those 2 small wires are the control wires. one is probably either ground all the time or hot all the time, and the starter button gives you whichever is missing, either one wire is ground all the time, and the button switches power, or one wire is hot all the time and the starter button suplies ground. when the starter relay sees power AND ground on the small wires it actuates, and connects the big battery positive to the big starter cable, supplying power to the starter, cranking the engine.
Old Nov 1, 2006 | 08:48 PM
durabostbay's Avatar
Probably stuck contacts in your solenoid/relay
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
