Raptor pulls to left when wheeling
Old Nov 8, 2006 | 01:55 AM
Raptor010101's Avatar
Default Raptor pulls to left when wheeling
When I ride a wheelie my raptor pulls to the left why is this?????
Old Nov 8, 2006 | 01:59 AM
BassBlaster's Avatar
Sounds like unequel(sp) tire pressures to me. Could also be that your axle isn't square in the housing to. If that is the case then you will soon have damaged sprockets and/or a chain. I would check tire pressures though. I see you sold two Raptors, did you get another one?
Old Nov 8, 2006 | 02:36 AM
I don't think its tire pressure?? I have an 03 Raptor also. Funnest quad ever made!! Let it snow!!
Old Nov 8, 2006 | 06:39 AM
Scooter86's Avatar
Knows Old ATV Questions!
One tire is getting more traction somehow. Either the pressures are off(and it doesn't take much) or you are leaning more to one side when you ride a wheelie. Could be a few other things, but those are the most likely.
Old Nov 8, 2006 | 11:19 AM
garyc660R's Avatar
After checking the tire pressures I would take a serious look at the axle alignment. Even the slightest bit out of alignment will cause this situation. If you have the alignment marks set correct and the problem persists try tightening the left side only little by little until the atv tracks straight. Obviously, one of the reasons the new Raptor uses a honda style of chain alignment / adjustment is because the old setup sucks.
Old Nov 8, 2006 | 03:25 PM
MasterRaptor's Avatar
Your left axle hub splines are stripped out. It's a common Raptor problem. Gotta keep the castle nuts torqued or else. Better fix it before you loose the wheel and crash. I seen it happen in front of me. Not pretty.
By the way I have an extra axle if this turns out to be the problem.
MikeyBoyesq
Nov 27, 2020 02:44 PM
WilliamBos
Sep 30, 2015 08:08 AM
wannabe32
Jul 7, 2015 11:30 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
