100 hr. belt check
Old Nov 8, 2006 | 08:16 PM
PrairiePilot's Avatar
Default 100 hr. belt check
I have 137 hours on my Prairie and the 100 hr belt trip or deal has not occured!!
Old Nov 8, 2006 | 09:05 PM
melloyello's Avatar
Have you already taken it in for your first service?
Old Nov 9, 2006 | 12:24 PM
Hayashi's Avatar
Your quad has two clocks, one in the dashmeter (137 hrs that you see) and the other hidden one inside the CDI. The 100-hr counting is done by the CDI clock not the dashmeter. Then, you may ask why aren't those 2 clocks counting the same hours? That's because the dashmeter clock counts even if the engine is not running as long as the ignition key is at the ON position. The CDI clock counts only if when the engine is running. The moral of the story is that "DO NOT" leave the key at the ON position if possible when the engine is NOT running so that those 2 clocks have the same amount of hours stored. Hope this explains.
Old Dec 6, 2006 | 11:26 PM
RalphM's Avatar
Is there a way of reading the cdi clock? Thanks
Old Dec 6, 2006 | 11:36 PM
v2rider's Avatar
I think the actual hrs start registering at a certain RPM
Old Dec 7, 2006 | 12:42 PM
FASTFATBOY's Avatar
Very good info. I wonder why they did it that way?
Old Dec 7, 2006 | 02:00 PM
RalphM's Avatar
Is it possible to read the hours and min. from the cdi clock?????
Old Dec 11, 2006 | 02:52 PM
Hayashi's Avatar
No, you can't read the hour reading (nor the min) of the clock inside the CDI. It's simply a counter that activates the belt light at every 100 running hour (at any running rpm). Remember those annoying "CHECK ENGINE" light that used to come on on some of the Japanese cars in the 80's even though there is nothing wrong with the engine but you can't pass the smog check if the light is on? The concept is same, reminding you to check.
Old Dec 11, 2006 | 08:49 PM
RalphM's Avatar
Ok Thanks.
Cummins Driver
Sep 11, 2019 01:22 PM
Hondapolaris8596
Jul 28, 2016 03:17 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
