'01 Recon Stalls Going Uphill
Old Nov 9, 2006 | 07:31 PM
Bigson's Avatar
Default '01 Recon Stalls Going Uphill
New guy here. Any help appreciated. I have a 2001 Recon that has not been used for awhile.
Iceaned the carb (twice). Runs, but seems weak, power wise. My worst problem is when I go up a steep hill, it dies. I can restart by choking. I believe the float needs replaced. Checked float level and it seems way too high to me. Like it is never closing off the needle valve. Should be getting plenty of gas. Seems like it is running out of gas with a full tank. Any suggestions? I must be missing something simple.
Thanks , Bigson
Old Nov 10, 2006 | 08:48 PM
Bigson's Avatar
Hellooooooooooo.........................someone out there has to know how to solve my situation!
I can't be the only person on earth with this problem. Send me some info please. Thanks in advance.
Brian
Old Nov 11, 2006 | 01:30 AM
bombrider04's Avatar
well since no one is responding I guess I will well my friends recon would conk out when ever riding it on woops and the choke would help when turned on but it ust ran horrible so I took the carb apart and the jets were clogged up pretty good and stuff was floating around the the bowl of the carb...so I cleaned the jets out making sure I could see through them and cleaner the rest of the carb pretty much spotless and man it ran great...so what I would do is if that gas has been sitting in there for a while its not good to keep running that through a clean carb as it could be clogging it up but if it only conks and sputters when going up hills I would have to agree the float is getting stuck and not allowing gas to get through...there should be an adjustment on the float to allow it to open and close and see if you can adjust it to make it better sounds like you are getting a lack of gas
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Jason Campbell
Sep 7, 2015 02:25 PM
