Warrior w/ no spark to the coil? FIXED THE PROBLEM
Old Nov 12, 2006 | 12:00 AM
Chopperrescue's Avatar
Default Warrior w/ no spark to the coil?
I know this has been posted by other members with the same problem but I couldnt find a good answer. I purchased a 96 warrior non-running thinking I could fix it. I have no spark getting to the coil, I replaced the battery and swapped CDI boxes with a another guys 96 warrior and still no spark. I have read maybe it could be a stator. I'm not that good with a meter and I'm not sure how to test it, but I did find wires coming from the stator and put a test light to them and it showed I was getting pulsing sparks when the engine turned over. It appears the stator has been replaced, I didnt pull the cover but the wires are pliced. Any help with doing another test?? how to do the test?? How hard is it to get to the pulse pickup on this model?
The clutch switch and headlights are missing off the atv, would this have something to do with no spark? also the starter switch button, the sliding kill switch, is it suppose to show hot on one side when the switch is on? I couldnt get a reading with my test light, I was wondering if the engine would still turn over if something was wrong with the kill switch? any help with a diagnosis will be appreciated. I know I have lots of questions, I'm trying to throw all of them out there to you. Thanks
Old Nov 12, 2006 | 12:30 AM
2FAST4URASS's Avatar
WELCOME TO THE FORUMS as for your spark its a 40 dollar part pulser pick up this man is the guru of stators cdi's etc. and is great help so go here www.rickystator.com and you will get the part you need he has fast shiping and as i said is great to deal with.. JEREMY
Old Nov 12, 2006 | 12:33 AM
Thanks jeremy I'll give them a try.
Old Nov 17, 2006 | 10:24 PM
The Stator was the problem! Called RM Stator and they sent me out one and boom, I had spark!! Let me ask what might be a silly question, is the case that the stator and pickup is in suppose to house oil? my case and stator was soaked in it? thanks
Old Nov 17, 2006 | 11:42 PM
scottd's Avatar
Default Warrior w/ no spark to the coil? FIXED THE PROBLEM
That's the way it's supposed to be...no need to worry.
Old Nov 19, 2006 | 10:53 PM
Told ya Rick is the man i figured he could help he is the elec man lol.Good riding to ya. JEREMY
njrider64
Jul 4, 2017 01:40 AM
WilliamBos
Sep 30, 2015 08:08 AM
Bigredjeep
Jun 22, 2015 11:30 AM
sae156
1) Engine problems..
Jun 3, 2015 01:45 PM
Lasher
Sep 10, 2000 06:00 AM
