90cc Engine help
Old Nov 12, 2006 | 01:37 PM
knauf's Avatar
Default 90cc Engine help
I am thinking about getting a 53 or 54mm top end kit for my kids quad. What would be a good carb size? Not looking to race just want a little more power. Thanks
Old Nov 13, 2006 | 03:20 PM
HQR109's Avatar
i would go with the 53. most the 54mm cylinders are for stroker cranks which will cause you motor to have way to much squish. that will cause low compression. on the carb go with a 20mm with a uni or k&n filter.
Mark
Old Nov 14, 2006 | 11:47 AM
BIGWORM3699's Avatar
Go with 53mm with a 28mm carb. Just ck with the parts vendor and tell them deck height and crank size so port timing is going to be correct.
Old Nov 15, 2006 | 11:20 AM
Fastestdad's Avatar
If you dont have any problems with your stock carb I'd just get the head redesigned and have the cylinder flaws fixed. Then it will run very well compared to stock. Shouldnt cost you more than $100 to $150. A few clutch mods will help a bunch too. Then It's still reliable as stock.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Bratman2
Aug 6, 2022 01:42 AM
Ramman1
Jun 16, 2016 09:07 PM
WILLLANE8302
1) Engine problems..
Aug 7, 2015 08:24 AM
vlkster
Jul 28, 2015 11:35 AM
