Honda 350 4x4, a check for bad bearings?
Old Nov 16, 2006 | 09:52 PM
Caper1981's Avatar
Default Honda 350 4x4, a check for bad bearings?
Hello,
My father has a 1990 Honda 350 4x4 that hasn't been used much in the few years and I took it out on a run this fall. About half way through the run it started bogging out and sqeaking,and it had never done this before. It would happen at random times and the machine would bog down a bit in power when it happened. It sounded like a car time sqealing. I'm thinking maybe the ball bearing in the front or the back might be shot and jamming up periodically. Does this sound right? Is there any ways to check see if this is the case without totally tearing apart the front diff or the rear gearbox?
Thanks in advance for the help.
Ian Mac Leod
Fredericton, New Brunswick, Canada
Old Nov 17, 2006 | 10:08 AM
mykool61679's Avatar
on my rancher it sounded more likes brakes squeaking, than a belt? on the rear just take the tires off and slide the covers off the axles and you should be able to see them. i think.
Mkp
Mar 28, 2020 03:50 AM
neilbedwell
Nov 10, 2018 11:02 AM
Rigit
Sep 29, 2015 03:02 AM
traumajunkie
Jun 23, 2015 03:15 AM
lovinhonda
Jan 25, 2000 09:17 PM
