Speedo sensor
Old Nov 23, 2006 | 07:03 PM
cobby's Avatar
Default Speedo sensor
Does anybody know how to test the speedo sensor on a 2001 500 HO? to see if its working?
Speedo is not working but I have 4X4. and the speedo lites up.
Old Nov 23, 2006 | 07:22 PM
SPORTSMAN70003's Avatar
TEST 6 WHEEL SPEED SENSOR
Tools Required:
GStatic Timing Light Harness (PN 2871745)
GHall Sensor Probe Harness (PN 2460761) or equivalent
jumper wires.
To test wheel speed sensor:
1. Disconnect 3 Pin connector from speedometer.
2. Connect wires from test light to sensor 3 Pin
connector as shown at right, using the Hall Sensor
Probe Harness (PN 2460761) or jumper leads.
3. Elevate front right side of vehicle until tire is off the
ground.
4. Slowly turn right front wheel while observing the
test light.
5. If light flashes, sensor is O.K. Be sure connections
are good and 9 volt battery is in good condition.
Old Nov 23, 2006 | 07:31 PM
PM me with your email address and I will send you the diagram and all that way what you read above will make sense.
Jeff Roper
Feb 1, 2022 11:48 AM
speedbuff
13
Nov 11, 2020 10:16 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Jeff Roper
Sep 21, 2015 02:11 PM
