07 bf 750 wont start. looking for insight!!??
Old Nov 25, 2006 | 09:28 PM
mcgilicuty's Avatar
Default 07 bf 750 wont start. looking for insight!!??
took my 07 brute force for a 40 mile ride this weekend, started and ran fine all day! started the motor and let it warm up before i unloaded into the garage soon as i rode it into the garage it stalled and has yet to restart, i did run it low on fuell this weekend but not totally empty it has spark, and will fire with a shot of ether. opened the carb drains and a small amount of fuel came out of both, about a fith of an ounce from each. just wondering if anybody else has encountered this same problem?? -dan oh and yes i did refill the gas tank before the last time i started it!
Old Nov 25, 2006 | 10:29 PM
RAMBLNMAN's Avatar
i think they have electric fuel pump ,check fuses
Old Nov 26, 2006 | 01:22 AM
mcgilicuty's Avatar
fuses are good, i got a feeling the fuel pump is bad, its goin to the shop mon. just wondering if others had this problem.
Old Nov 26, 2006 | 01:49 AM
RAMBLNMAN's Avatar
I THINK THEY ARE LOCATED IN TANK SO MAYBE IT OVERHEATED AND BURNED OUT RUNNIN IT CLOSE TO EMPTY I CANT IMAGINE IT WOULD BUT YOU NEVER KNOW ITS UNDER WARRANTY RIGHT?
Old Nov 26, 2006 | 03:09 PM
bfb750BF's Avatar
First before you haul it down to the Dealer is:
Your Fuel Tap.
It is located under the Control unit (under the seat).remove the control unit to access the Fuel tap. Turn the fuel tap from "On" to "PRI".
If the BF starts and idles fine, then turn the Fuel tap back to "ON" .
Old Nov 26, 2006 | 09:25 PM
mcgilicuty's Avatar
tried turning the tap to pri and turning the eng over, with no luck. that was yester day. went to the garage to night gave it full choke hit the start button and it fired right up. so i dont know what the deal is, but now i dont trust the damn thing to start. at least if something was broke and i had it fixed. that would gimme piece of mind.
Old Nov 26, 2006 | 11:18 PM
alltoos's Avatar
Sometimes those little gremlins can be a pain. Sometimes you need to check thing 1 by 1 to corner the problem. Check to see if you have spark and then fuel. I think from the sounds of it you have a fuel issue. But don't know for sure. It is a good thing it started though.
Old Nov 27, 2006 | 02:11 AM
bfb750BF's Avatar
Sounds like the primer fixed the problem. You may have had air-pockets in the fuel line during the "PRI" start.
Old Nov 27, 2006 | 12:02 PM
melloyello's Avatar
That's what it sounds like to me too.^^^^You ran it out of fuel so you had to give it time to get the air out of the fuel system and fill the carbs. That takes quite a few revolutions of the engine to do. When you turned it to prime you fixed your problem.
salixair
Nov 3, 2015 08:25 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
2many2ride
Sep 27, 2015 04:35 AM
rgjackson
Sep 17, 2015 11:21 AM
