Should I buy Chinese synthetic Oil or Japanese dino Oil??
Old Dec 1, 2006 | 02:11 PM
2or4wheels's Avatar
Default Should I buy Chinese synthetic Oil or Japanese dino Oil??
[img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
I may get into trouble for wasting Bandwidth on a dopey post, but oh well.....nothing stirs the pot like a good old oil debate....
-d3
Old Dec 1, 2006 | 04:46 PM
2manytoys's Avatar
Well it depends on the application. Me being a master certified mechanic can tell you that synthetic oil is far superior over regular dyno oil. BUT if you change your oil on a regular basis dino oil is just fine and will protect just as good. Its the higher heat, higher performance, lazy maintenance applications that synthetic oil protects alot better because it does not break down, gel or burn like regular oil. I do not recommend using synthetic oil in older vehicles because all kinds of problems can happen.
Old Dec 1, 2006 | 11:14 PM
hoytultratec's Avatar
Originally posted by: 2manytoys
Well it depends on the application. Me being a master certified mechanic can tell you that synthetic oil is far superior over regular dyno oil. BUT if you change your oil on a regular basis dyno oil is just fine and will protect just as good. Its the higher heat, higher performance, lazy maintenance applications that synthetic oil protects alot better because it does not break down, gel or burn like regular oil. I do not recommend using synthetic oil in older vehicles because all kinds of problems can happen.
what he said!
hey 2many where motof150?
Old Dec 2, 2006 | 10:30 AM
2manytoys's Avatar
HMMM dont know, where is he? LOL!
Old Dec 2, 2006 | 11:29 AM
1976's Avatar
I also heard you shouldn't switch them back and forth, if you are going to use one type stick to it, otherwise you may have a handful of engine problems down the road. (Something I heard, don't quote me on it [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 2, 2006 | 08:09 PM
2manytoys's Avatar
Thats an old myth. Back when synthetic oils first came out they were not compatible with each other but now regular oils are so much better and you also have semi synthetic it will not hurt to switch. Some people even mix like 1-2 qts of synthetic with 2-3 qts of dino.
Old Dec 2, 2006 | 09:54 PM
1976's Avatar
I personally wouldn't do it, there is a reason why conventional oil and synthetic oil are bottled seperatley, or there would be called conventethetic oil (maybe i'm onto something though?)
Old Dec 2, 2006 | 10:05 PM
mykool61679's Avatar
thet do make synthetic blends.
Old Dec 2, 2006 | 10:28 PM
2manytoys's Avatar
Yes thats why they make semi synthetic and blended synthetic.
fredrikrosen
Oct 29, 2016 07:56 PM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
01ssls1
Sep 22, 2015 06:50 AM
CosmoM
Sep 21, 2015 04:57 PM
Alex G.
Sep 19, 2015 06:34 PM
