Belt wet 800xt
Old Dec 2, 2006 | 09:40 AM
Captdan's Avatar
Default Belt wet 800xt
Anybody have problems with belt getting wet on 800 xt...Mine got wet smoked outer primary clutch...Holes warn in it , never seen this before...
Old Dec 2, 2006 | 12:53 PM
Cardiac's Avatar
You can take all the "shootouts" and put them in one bucket and you won't have beans.
How deep a waterhole did you go through? Did the water get in the intake snorkle for the belt housing? Did you check to see if the housing was sealed. A few have been shown to warp with high heat. There is also the slight possibilty that the water can get by the seal on the back side of the housing. You say that holes were worn in it. In what? If the holes are worn in the housing, someone was resting there feet on it when they shouldn't have.
Old Dec 2, 2006 | 06:32 PM
propolaris's Avatar
I seen on here some where some guys made made made a film of them playing in mud and water and they said that the outty was bad about getting belt wet.
Old Dec 2, 2006 | 06:34 PM
Cardiac's Avatar
Is that the same one where they were working hard to pull the Popo out of the mud?
Old Dec 2, 2006 | 06:51 PM
propolaris's Avatar
I don't remember seeing that maybe different video, We all have pulled somebody out of the mud, What does popo mean!!
Old Dec 2, 2006 | 07:01 PM
kawiyowee's Avatar
Same as poopoo. We can say it plainer for you if you like.
Old Dec 2, 2006 | 07:07 PM
Captdan's Avatar
it was water just above the tires, I guess the water got in behind the housing....Dealer is going to seal and replace clutch....I hope
Old Dec 2, 2006 | 07:08 PM
Captdan's Avatar
Holes were warn in clutch outer ...The part that moves in and out...
Old Dec 2, 2006 | 07:17 PM
BBR650's Avatar
Is always changing bikes.
the intake duct for the belt cover is located in the top of the left inner fender. if the plastic moves or distorts it will suck a little water. how on earth could you wear holes in the clutch?
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
