360 KVF (Prarrie)
Old Dec 3, 2006 | 11:52 PM
harry1's Avatar
Default 360 KVF (Prarrie)
Hi folks....I just purchased the '07 KVF 360 4X4 (prairie) and I've found the primer **** on the left side of the carb. I'm here up in Canada and all our sleds have primer *****...but the primer **** is totally unreachable on this bike w/o getting a screwdriver and removing some panelling! Seems like a real afterthought and really dumb. Although it states that primer is only used for -20 C that is still a real temperature for me up here. Has anyone seen this ...is there an aftermaket extension kit for the primer?
Dave
Old Dec 5, 2006 | 03:11 PM
alwaysride's Avatar
i have not heard of any aftermarket extensions. Full choke i would imagine would get the beast to life in the cold. Works fine for me when im near 0 degree temps.
Old Dec 5, 2006 | 05:29 PM
denbigh57's Avatar
I have a 2006 with the same problem. I also live in Canada. Last year did not need to use primer only the choke.
I had that question with the dealer I purchased the machine from and was told if you have to use the primer use a long screw driver or stick. You may flood the engine if you use it the way the manual tells us to.
I would sugest you keep an eye on the exhaust vavle. When you come to a stop and the engine stops to this may be your problem. This is from experiance. Denbigh57 Good luck and have fun
Old Dec 5, 2006 | 07:40 PM
harry1's Avatar
[i]
Hello denbigh....did you end up burning up your exhaust valve? I suppose this to be common with this machine?
DaveP
Old Dec 6, 2006 | 10:29 AM
denbigh57's Avatar
harry 1. No I did not burn the exhust valve, got lucky on this one. It took 1 year for the people in con cern to get this figured out. Now it runs tooo good. Have fun with your play toy. Do you have tracks for it I do . You can go any where with them, slower than a sled b
,you only need one machine .
harry1
Nov 25, 2006 02:09 AM
CAridgerunner
Nov 18, 2004 12:01 AM
cc1999
Oct 18, 2004 07:29 PM
GOODGUY
Oct 13, 2004 09:56 PM
GOODGUY
Oct 11, 2004 06:09 PM
