LT80 Shocks
Old Dec 16, 2006 | 04:06 PM
Irunwire's Avatar
Default LT80 Shocks
Okay one more qusetion from a newbie. I have done a search and have found little info on this subject so here I go. I am putting the JLATV front A arm extenders on and know that the wheels will pull in on the to due to the stock shocks. Are the Polaris Predator 90 shocks longer and will they work on the rear also. Thanks for all the input on this LT80.
Old Dec 16, 2006 | 06:42 PM
Uptmor250r's Avatar
Default LT80 Shocks
Irunwire
I put trx90 on the front. The elka where 5/16 longer than the stock ones. They work great. The rear has to be one for the lt80.
Old Dec 17, 2006 | 12:42 AM
Irunwire's Avatar
Default LT80 Shocks
Ok, I did the math and I need shocks that are about 10 1/4 inches center to center because the JL extenders add 6 inches to the width. So assuming(you what that means) that each side is a 3 inch extnesion then I need to add about 3/4 inch to the shock to keep the angle on the spindle the same. So does anybody have any idea what shocks I could use. I measured the shocks on my daughters TRX90 and they are almost identical to the LT80s. Now the rear shock is close to what I need but not sure how they would do but they are somewhat adjustable. Any ideas? [img]i/expressions/face-icon-small-confused.gif[/img]
QuadRiders
Oct 22, 2015 04:13 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
