LT80 Shocks
Okay one more qusetion from a newbie. I have done a search and have found little info on this subject so here I go. I am putting the JLATV front A arm extenders on and know that the wheels will pull in on the to due to the stock shocks. Are the Polaris Predator 90 shocks longer and will they work on the rear also. Thanks for all the input on this LT80.
Ok, I did the math and I need shocks that are about 10 1/4 inches center to center because the JL extenders add 6 inches to the width. So assuming(you what that means) that each side is a 3 inch extnesion then I need to add about 3/4 inch to the shock to keep the angle on the spindle the same. So does anybody have any idea what shocks I could use. I measured the shocks on my daughters TRX90 and they are almost identical to the LT80s. Now the rear shock is close to what I need but not sure how they would do but they are somewhat adjustable. Any ideas? [img]i/expressions/face-icon-small-confused.gif[/img]
