250 utility reverse/ start-up problems
Old Dec 18, 2006 | 07:34 PM
kevlar119's Avatar
Default 250 utility reverse/ start-up problems
On my 06 250 utility I have 2 problems hopefully someone on here can help me with. The first one is that once the engine is warmed up - been ridden for a few minutes - when I go to shift from N to R or H, it stalls. I am able to get it to start again with some pampering of the choke - but as soon as I give it some gas, it stalls again. I have to shut it off and wait about 5 minutes and restart it - then it's fine. The second problem is that once in R - it sputters and loses power - put it back in H and it's fine. I was initially having problems with low power but believe it was due to old gas - I added gas with stabil in it and that seemed to stop my last problem. Any suggestions on these two items? Thank you in advance.
Old Dec 18, 2006 | 08:50 PM
Bear4570's Avatar
It should still be under warranty, take it to your dealer. If you screw around with it you could void your warranty.
Old Jan 4, 2007 | 01:16 PM
kevlar119's Avatar
OK... the backing up issue was simply the over-ride button- I figured that out yesterday. The problem with it stalling after it's warmed up while shifting from n - h still exists. I dropped it off at the dealer this morning... he said if it's carb related- it isn't covered under warranty! I told him it has the 3 yr bumper -to-bumper warranty - still not covered! Anyone have the email to AC to complain? I couldn't find it on their website. Thanks!
Old Jan 4, 2007 | 04:02 PM
Bear4570's Avatar
Sure;
Arctic Cat Phone numbers and E-mail
1-218-681-4999 or 1-218-681-9799, one of the numbers only works once in a while. The other will work all the time but I forgot which is which. The email is: consumeraffairs@arcticcatinc.com . I would email them and tell them the whole story of your problems. They should handle it, maybe even called your dealer or find you a new dealer, set up an appointment even.
FYI; The dealer should have done a carb adjust before delivery, or he ripped you off on a setup charge.
Old Jan 4, 2007 | 08:38 PM
Derecho's Avatar
I bought my son this same machine this past summer. It has worked very well for him but we also had some problems with it stalling when shifting or idling. I took it in for its first service at 250miles and they cleaned the fuel filter and made an adjustment on the carb (idled too low). It was a simple fix for us and part of the machines 1st service.
Old Jan 4, 2007 | 10:17 PM
kevlar119's Avatar
Thanks for all the info - I'll be emailing them in the morning.
Were you charged for the 1st service? I was told the 1st service would be abot $200 per machine!! Other mfg/dealers were offering 1st service free - didn't even think about asking this dealer or AC brand.
Old Jan 5, 2007 | 04:33 PM
Derecho's Avatar
I actually bought this machine from a delearship 90 miles away, therefore did not worry about trying to get a free first service. I really don't know how common that is, especially when you get a good deal on a machine. My 1st service cost me around $125.
Firefighter400
Oct 8, 2022 06:38 PM
Nondem
Feb 22, 2020 12:20 PM
greg74
Sep 10, 2019 03:03 PM
RickyMac
Mar 5, 2016 07:27 AM
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
