paint
Old Dec 26, 2006 | 11:21 PM
cammok5's Avatar
Default paint
what kind of paint is best to use on my quad.
Old Dec 26, 2006 | 11:54 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default paint
for doing what?
Old Dec 27, 2006 | 07:49 AM
fastblaster00's Avatar
Default paint
if u just spray ur fenders good luck with that. its just gonna crack.
Old Dec 27, 2006 | 10:23 AM
u1arunit's Avatar
Default paint
Do you mean for the frame?
If you mean for the plastic, it's best just to buy new plastic.
Old Dec 27, 2006 | 10:28 PM
BassBlaster's Avatar
Default paint
As stated above it is best to just buy new plastic. You can get it pretty reasonable on ebay. If you still want to paint it, I have heard of guys using paint called Fusion. I guess it is specifically for plastic but I have never tried it.
Old Dec 29, 2006 | 09:42 PM
crazypainter's Avatar
Default paint
Fusion doesn't stick to ATV plastic very well. Not much out there does.
Old Dec 30, 2006 | 02:20 PM
kfxandahemi's Avatar
Default paint
Paint will work fine on fenders if you are not lazy and take the right steps to prep it. Sanding it so primer will stick is key... and using a good paint that wont crack is also key. Here is a link to a pic of my Banshee that my bro and I painted. It wont crack at all. Ive flexed all the pieces and they are fine. If you dont want a basic blah set, paint them how you want them, its a fun project, and then nobody has one like you either. Heres the pics...
Pic 1
Pic 2
Old Dec 30, 2006 | 09:51 PM
beaty's Avatar
Default paint
im painting a blaster and the first time i painted it i used regular spray paint and it stuck till i spilt gas on it and then it looked crapy so we just sprayed it with gas and got all the paint off now were painting it with fusion and so far its fine
Old Dec 30, 2006 | 11:33 PM
cheitman's Avatar
Default paint
Prep work is key. There is a plastic specific prep/degreaser and an adhesion promoter. Go to your local auto body paint and supply dealer, they will lead you in the right direction. i painted the plastic on my Warrior using an Acrylic Enamel. It was a cheap paint, easy to spray and touch up down the road. It has help up well for nearly 2 years now.
Old Dec 30, 2006 | 11:56 PM
Default paint
Yes... prep is the key.
nachop
Feb 14, 2018 06:57 PM
95wolv
Jul 21, 2015 12:25 PM
Reactant
Jul 16, 2015 10:29 PM
hiofcer
Oct 5, 2000 04:43 AM
