Blaster help needed
Old Dec 29, 2006 | 11:01 AM
mxracer50's Avatar
Default Blaster help needed
I have a 1990 blaster that has low hours on it but has been sitting for about 5 years. Well I have cleaned the gas tank and carb, removed the TORS, put a new coil on it , replaced the crank seal on the clutch side but it still won't run correctly. It will start first kick, idles perfect, revs up like it should but as soon as you try and ride it, it won't run , just bogs down and won't make any power. Anyone have any ideas?
Old Dec 29, 2006 | 08:55 PM
Yamahariders3's Avatar
Hi, Did you get the carb and jets cleaned up real good? After 5 years of sitting, if there was any gas in the carb or tank it's probably gummed up. Also, there could be air leaks somewhere.
Old Dec 30, 2006 | 01:19 AM
JLsparky7's Avatar
+1, thats my guess, I would take the carbs completely apart and soak them in carb cleaner.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
Djinn
Aug 31, 1999 10:36 PM
