Low gear grind
Old Jan 27, 2007 | 09:12 PM
horseman54's Avatar
Default Low gear grind
I have a 99 Polaris Sportsman 500 4X4. Lately I have been having trouble getting into low gear. When I put the lever over and up, and give it some gas it kicks out of gear. When I try to put it back in it grinds. Sometimes it will catch when I apply pressure to the lever. Does this sound like a gear is getting wore out or what? I use this to pull a manure spreader about twice a week and it's getting worse now. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 27, 2007 | 10:36 PM
trailbound's Avatar
We had a similar problem on a polaris transmission. What we found was where the gear selection rods went back to the trand and turned a shaft in the top of the trans the bushing was worn out. We just adjusted the linkage but replacing the bushing would have worked to. Check if these input shafts are loose.
Old Jan 28, 2007 | 09:43 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes check the linkage for sure. sounds like it isnt able to go in to low all the way.
Old Jan 28, 2007 | 10:17 PM
Kerbbirds's Avatar
Put it in nuetral and adjust the linkage so both ends of the rods are straight up and down with were they attach, check for worn bushings also.
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Minimod
Sep 10, 2015 08:03 AM
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
