scrambler 500 4x4 clutch
Old Jan 30, 2007 | 09:31 PM
ltdaddyo's Avatar
Default scrambler 500 4x4 clutch
need to know the best clutch to get. gotta white bros pipe,mud lites,need to set it up for trail,mud but dont want to loose top end .any input would be appricated thanx
Old Jan 30, 2007 | 10:41 PM
ftwflh's Avatar
It isnt always that simple as to "what clutch do I need" It also depends on how much you want to spend and exactly what you want out of your machine.Such as how you want it to engage,where you want most of your power,what rpm do you want to run on topend,how you want it to backshift........and more.
I have mine set to run 6600rpm on top,engage close to 2000rpm,have most the power in the midrange and backshift instantly.
My recomendation would be first get you a tach.Then a TEAM roller secondary and a Dalton blk/white primary spring with stock weights.THen see where you are at on the rpms and dial it in with weights and maybe a differant spring.
fordfaithful21
Dec 7, 2015 05:52 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
1000gade
Sep 9, 2015 03:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
