2005 magnum 4x4 trans. problem
Old Jan 31, 2007 | 10:10 PM
Magnum330's Avatar
Default 2005 magnum 4x4 trans. problem
It will go into all the gears except for park.there is no adjustment on the shift rod.The bellcrank is intact and not stripped.I have been using it to plow snow and havent had any problems other than that.I thought about changing the trans. oil to see if there is some water in it.Any other advice would be helpful.
Old Feb 1, 2007 | 10:10 AM
jta4455's Avatar
will it go into high range if not check the spring that moves the little detent that allows the atv to go into high or park when pressing the foot brake, if the spring isnt there it wont go.
Old Feb 1, 2007 | 10:37 AM
Magnum330's Avatar
the spring is there.I looked at another magnum like mine,im thinking the selector detent inside the cover is bent.There is also alot of play in the shifter when in high gear
Old Feb 1, 2007 | 10:39 AM
Magnum330's Avatar
I know that is sealed off from the rest of the transmission.If it isnt that i guess the transmission will have to come apart.
Old Feb 1, 2007 | 04:32 PM
Magnum330's Avatar
Well I took the cover off the transmission.The gear selector gear had missing teeth.13$ and it will good as new.Apparently had gotten water in there and froze causing it to break.
Shifts
14
Jul 13, 2015 08:41 AM
tporath
Jul 11, 2015 12:31 PM
steveo612
Jul 11, 2015 08:35 AM
jettman
Jul 6, 2015 12:16 PM
Shifts
Jul 3, 2015 07:59 AM
