TB Cluch help
Old Jan 31, 2007 | 11:05 PM
Gurney's Avatar
Default TB Cluch help
Hey i just took off my secondairy cluch spring that i got Rick Ritter....i took it off because i seemed to lose performance w/ it....i forget the settings i had it on but is there anybody that could help me w/ the settings so i can put it back in
Old Jan 31, 2007 | 11:19 PM
ftwflh's Avatar
Set it at 2-2 and preload it by turning 1/3 turn before pushing it down on the splines.
Old Jan 31, 2007 | 11:22 PM
Gurney's Avatar
ok and the pre loading is gonna do what...and what is the spring exactly gonna do?
Old Jan 31, 2007 | 11:31 PM
ftwflh's Avatar
You have to have the spring loaded for the clutch to work.So that the clutch halves will open letting the belt go down in it and when you slow down the belt comes back to the top.
Preloading can be a 3 handed job if you havent done it before.
Old Jan 31, 2007 | 11:34 PM
Gurney's Avatar
is it ok to go over 1/3 a turn for preloading?
Old Jan 31, 2007 | 11:37 PM
ftwflh's Avatar
It isnt nessecery.1/3 turn will get the hump on the helex over the ramp button.
Old Feb 1, 2007 | 10:46 PM
Gurney's Avatar
Ok sound like a plan.....2-2 and 1/3 turn preload.
Old Feb 2, 2007 | 12:13 AM
Gurney's Avatar
Ok...i have been reading a bunch of forums about cluch weights....well i do not have any...or have stock ones...any ideas
Old Feb 2, 2007 | 12:19 AM
310's Avatar
310
Well, the stock weights are 16:43g or if above 6000 feet then 16:40g weights. That is the stock weights from the manual.
bvandass
Oct 8, 2015 09:13 AM
Jordanw
Dec 18, 2004 11:54 PM
rutelis
Oct 1, 2004 07:50 AM
Jordanw
Sep 21, 2004 02:34 AM
raptorblasterracer
Feb 19, 2004 09:45 PM
