no power to highbeam headlight 01 sportsman 500
Old Feb 1, 2007 | 10:30 AM
diffinman's Avatar
Default no power to highbeam headlight 01 sportsman 500
01 Sportsman 500. I have no power to the main hi-beam headlight. The two low beam work just fine. Any suggestions? Fuse? Hi beam light is on at the switch.
Old Feb 1, 2007 | 11:35 AM
MikeT133's Avatar
The first thing I would do is pull the high beam bulb, and check that your getting 12 volts to the bulb socket. If not you've got a wiring problem between the switch and the bulb socket. If you've got voltage at the socket then most likely a bad bulb, you can check for continuity through the bulb just to be sure.
Mike
Old Feb 1, 2007 | 12:28 PM
diffinman's Avatar
Thanks Mike,
I have check the bulb and it test fine. I do not have power to the plug at the light. I was wondering if there are any fuses, or a method to check the light switch.
Al
Jmuddin284
Jan 19, 2026 07:16 AM
Nondem
Feb 22, 2020 12:20 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
Shifts
14
Jul 13, 2015 08:41 AM
tweeder
Jul 5, 2015 01:57 PM
