taking bets
Old Mar 24, 2007 | 10:47 PM
TBJAY's Avatar
Default taking bets
I forgot my battery in the trail boss all winter what are the odds of it still holding a charge!!!!!! i will find out monday hopfully and hopfully it holds a charge again. hopfully it pull starts i only ever pull started it once but then again it is only 1 year old
Old Mar 24, 2007 | 10:50 PM
hoytultratec's Avatar
Default taking bets
it should be ok, but if its totally dead i have read not to run a polaris with a dead battery you will blow all the light bulbs out the guy i bought my used polaris from had that problem and i read it on here. dont take the chance charge the battery.
hoyt
Old Mar 24, 2007 | 10:52 PM
SCRAMMYTODD's Avatar
Default taking bets
I usually leave the battery in my Mustang all winter and it always starts in the spring. Same with my bike but I ride it all winter so I guess that doesn't count. Just make sure the battery isn't frozen and put it on a trickle charger and it should be fine.
Todd
Old Mar 24, 2007 | 10:55 PM
TBJAY's Avatar
Default taking bets
so in other words if it is dead remove it before i pull start it? wont the alternator charge it? (or what ever it has)
Old Mar 24, 2007 | 11:04 PM
Default taking bets
do a search on here on batterys youmight find something or wait for more replies on this im sure you will here more.
ive pulled started mine when the battery was low but it wasnt completely dead i had no problems its when the battery is dead i heard these things happen.
hoyt
Old Mar 24, 2007 | 11:06 PM
Default taking bets
search battery i found it couldnt copy and paste link
hoyt
Old Mar 24, 2007 | 11:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default taking bets
dont ever run the bike w/out a batery in it. if the battery was fully charged and full of acid then its probably fine. i left my 800 battery in all winter w/out starting and it started up. your charging system is for more maintaing the battery then as a charger but it will do it if you run it long enough and above idle.
Old Mar 27, 2007 | 05:24 PM
TBJAY's Avatar
Default taking bets
Well it started right up yesterday no problems. I cannt wait till i can go for a ride now
i just got my new full face helmet in the mail today too.
Old Mar 27, 2007 | 05:55 PM
trailblazermudrunner's Avatar
Default taking bets
i have dun that tho i went out to day and pulled out mi bikess....but i had pulled them out and put the battires in the closet
Sep 1, 2015 01:45 AM
snowolson
Aug 31, 2015 03:51 PM
DFWSRT8
Aug 20, 2015 09:24 AM
GearheadMOM
STOLEN
Aug 8, 2015 11:47 AM
mdigitale
Aug 6, 2015 12:35 AM
