01 Sportsman 500 HO starting problems
Old Apr 8, 2007 | 09:40 AM
bs1173's Avatar
Default 01 Sportsman 500 HO starting problems
I have been having problems starting my sportsman for a while. Most of the time when I try to start it it tries to turn over, but doesn't seem to have enough power to, even with a new battery. Sometimes after I try 5 or 6 times it will turn over and start, but not always. Even trying to hand start it is almost impossible. Last year I broke the handle off the pull start cord trying to pull start it. Maybe something is sticking, or the decompression isn't working properly?
Thanks,
Brian
Old Apr 8, 2007 | 11:03 AM
03scrambler500's Avatar
Sounds like the decompression is not working right. There is a little spring that enables it and if it breaks or becomes weak it doesn't work anymore.
Old Apr 8, 2007 | 12:14 PM
bs1173's Avatar
Do you know where it is or how to fix it?
Old Apr 8, 2007 | 01:36 PM
Overdrive's Avatar
It's on the end of the cam.
Old Apr 8, 2007 | 02:39 PM
there is a cap on the side of the engine if you pull the cap of you will see the spring.
Old Apr 8, 2007 | 11:27 PM
bs1173's Avatar
ok, I'll check it out when I get a chance. Thanks.
Old Apr 12, 2007 | 09:58 AM
bs1173's Avatar
I don't know much about engines and I looked up the schematics on bike bandit, but they weren't much help. If someone could give me a little more direction on what the cap looks like and where to find it on the engine that would be great.
Old Apr 12, 2007 | 08:44 PM
part 10 in this diagram http://www.partsland.com/index.cgi?N...00-HO-CYLINDER is the cap when you remove this make sure you put a new O-ring on part 7. Now what you will see under the cap is part 16 the relase lever and 17 the return spring in this diagram http://www.partsland.com/index.cgi?N...KE-and-EXHAUST if the spring fails it will not pull the lever back and will make starting really hard like your case
Jason
Old Apr 12, 2007 | 09:22 PM
bs1173's Avatar
Thanks,
That looks like it will help a lot. I will look at it when I get a chance.
Brian
whitty
67
Feb 24, 2021 02:52 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
