01 Sportsman 500 HO starting problems
I have been having problems starting my sportsman for a while. Most of the time when I try to start it it tries to turn over, but doesn't seem to have enough power to, even with a new battery. Sometimes after I try 5 or 6 times it will turn over and start, but not always. Even trying to hand start it is almost impossible. Last year I broke the handle off the pull start cord trying to pull start it. Maybe something is sticking, or the decompression isn't working properly?
Thanks,
Brian
Thanks,
Brian
part 10 in this diagram http://www.partsland.com/index.cgi?N...00-HO-CYLINDER is the cap when you remove this make sure you put a new O-ring on part 7. Now what you will see under the cap is part 16 the relase lever and 17 the return spring in this diagram http://www.partsland.com/index.cgi?N...KE-and-EXHAUST if the spring fails it will not pull the lever back and will make starting really hard like your case
Jason
Jason
whitty
67
02-24-2021 02:52 PM
