High rev 1996 polaris 250 trailblazer
Old Apr 9, 2007 | 08:26 PM
Sumkid707's Avatar
Default High rev 1996 polaris 250 trailblazer
Okay so i have a 1996 polaris 250 trailblazer that is revving up on its own when its just sitting there (idling) in neutral. the thing is when it starts revving up and reaches high rpm's it just stays there at that exact "speed" even when i shut off the key. the only way i can get it to stop is if i hit the throttle and then it revs down and finally turns off. Also, if i shift into forward before i turn on the quad it doesnt rev up it just idles normal until i start to ride than it will occasionally will rev up and speed up on its own untill i , again, tap the throttle hard then it revs down and i have complete control of the quad's throttle. PLEASE PLEASE HELP ME!!
Old Apr 9, 2007 | 08:32 PM
onesavage's Avatar
almost sounds like too much air...
Old Apr 9, 2007 | 08:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
usually a rising idle like you describe is caused by an air leak causding it to be extremly lean. only other thing is the throttle cable being stretched making it pull the throttle open.
Old Apr 9, 2007 | 08:39 PM
Sumkid707's Avatar
Yea, thats another thing, when i had the air filter off and covered up the opening with my hand so just a little air could get in, it reved down to normal....my next question is how to fix that cuz i obviously cant keep my hand over the opening when im riding :-)
Old Apr 9, 2007 | 08:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
although that would be a neat trick if you could. lol. you nee to find out where the air leak is. carb boot, crank seal?
Old Apr 9, 2007 | 08:44 PM
Sumkid707's Avatar
i think it might be the crank seal, i forgot the last owner neve put a gasket on it and i never put a new one on.
Old Apr 9, 2007 | 08:50 PM
Sumkid707's Avatar
could you guide me, using this link( http://parts.atv-parts-center.com/Po...p?Type=12&A=70 ) on which part i would need to buy
Old Apr 9, 2007 | 08:52 PM
onesavage's Avatar
both very easy fixes,i have done both them to the wifes tb..no big deal ..are you running the factory air box or have you tried to mod it AT ALL!!!
Old Apr 9, 2007 | 08:54 PM
Sumkid707's Avatar
its factory
Old Apr 9, 2007 | 09:07 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would test it first to make sure thats it b4 you go pulling it apart. you need to eliminate the throttle cable to make sure its not that. spray some car cleaner or ether down by the seal to seal if the rmps pick up and by the carb boot, be very careful if you use starting fluid as its highly flammable and could cause a fire easily.
