High rev 1996 polaris 250 trailblazer
Old Apr 9, 2007 | 09:13 PM
onesavage's Avatar
Default High rev 1996 polaris 250 trailblazer
yep, do what sten said... and make sure its not your throttle cable viberateing or something to that effect...when you say you air box is stock. we are talking right down to the snorkel and factory filter... no holes drilled or large cracks... .. i had a simalier issue but i was not running the airbox snorkel and it was running way lean..
Old Apr 9, 2007 | 09:43 PM
trailblazermudrunner's Avatar
Originally posted by: stendori
i would test it first to make sure thats it b4 you go pulling it apart. you need to eliminate the throttle cable to make sure its not that. spray some car cleaner or ether down by the seal to seal if the rmps pick up and by the carb boot, be very careful if you use starting fluid as its highly flammable and could cause a fire easily.
me and sten know about the fire thing but we didnt have ANY starting fluid
Old Apr 3, 2017 | 12:45 PM
Evan Switzer's Avatar
Ok I found the problem it was the little jet that was dirty
Nondem
Feb 22, 2020 12:20 PM
Shifts
14
Jul 13, 2015 08:41 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
MNatv89
Jul 7, 2015 11:36 AM
