lost power in xplorer 400
Old Apr 9, 2007 | 11:08 PM
trigger2458's Avatar
Default lost power in xplorer 400
I just put a hot seat pipe on my 98 xplorer that i bought used. Now my bike has no power at all! Any help would be great.
Old Apr 9, 2007 | 11:39 PM
Edwards's Avatar
Did you install the whole kit - pipe, carb jetting & clutch kit? If so, you said it was used, make sure there is nothing that got put in the pipe - mouse nest or something.
Old Apr 10, 2007 | 07:35 PM
waltondamron's Avatar
Did you put on pipe only? You will had lost power bottom end must have go to clutch kits and carb rejet main.I think you need a buy one clutch kits, If air fitler stock box go to carb reset jet main at 220 hot temp and jet main at 230 cold temp.
Hope this help
Old Apr 10, 2007 | 09:51 PM
specialkay's Avatar
waltodamron, I have a 01 400 Explorer with almost the same mods as you except I have the 38 tmx carb and the stock head. I upgraded the springs with the factory h/d springs but am not really happy with the suspension. Did you get yours from a Scrambler? Right now the back is ok but the front is too stiff on slow trails and it makes the quad tippy and more often than not I'm carrying a wheel in the air because the front doesn't articulate at all. Iwas actually going to put the original springs back in it and use a spacer to level it to the back. I weigh 230 lbs and even with my wife on behind me it's stiff. Any tips would be appreciated, Steve
Old Apr 12, 2007 | 07:57 PM
Specialky. My xplorer 400 a parts from dealer books pure accessorize 2002. I have one get book pure accessorize 2002 order hot seat shock for xplorer 400 front 6.7 hot seat shock and rear 9.0 hot seat shock. I had only stock spring front and rear.But scrambler shock will not fit for xplorer that is diff size because tall shock than my xplorer is small shock.
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
cornermike
Jul 8, 2015 11:44 PM
