Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
2-Stroke engine
Old Apr 13, 2007 | 12:03 AM
CONGEROID's Avatar
Default yea i no wut u mean nd i culkd deff use a fresh start
Im thinking bout getting a trailblazer 250 and i would like to know the difference between a 2 and 4 stroke engine. and the pros and cons of a 2-stroke.
Old Apr 13, 2007 | 02:16 AM
TLC's Avatar
TLC
Default 2-Stroke engine
Pros for 2 strokes:
More power per cc.
do not have to change oil ,you just add it.
lighter motor.
Cons:
Uses more gas.
have to add oil.
Louder.
Old Apr 13, 2007 | 07:06 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Some say 2 stoke engines are higher maintenance. If your handy with a wrench and do regular keep up work on a 2 stroke it will last you forever. 2 stroke engines are very simplistic and easy to work on. 2 strokes are smaller and do put out more power per c.c. One thing I personally do not like about then is that you are either stopped or haulin' tail. There is no putting around on one. 2 stroke's are known for there power band which once it kicks in you gone there is no easing into it. I would ride one before you purchase for sure.
Old Apr 17, 2007 | 02:04 AM
yfzdreamer's Avatar
Originally posted by: TLC
Pros for 2 strokes:
More power per cc.
lighter motor.
Cons:
Uses more gas.
have to add oil.
Louder.
louder is not a con [img]i/expressions/face-icon-small-happy.gif[/img] BBBbbbrrrrrraaaaaAAAAAAPPPPP!!!
Old Apr 17, 2007 | 02:26 AM
pabst660r's Avatar
2 strokes can be a pain because if you mess up your premix ratio you can lock the motor up.or in your case on a trailblzer if the oil injection messes up your screwed.
but 2 strokes have less internal parts than a 4 stroke so rebuilding them is alot cheaper too.with the exception of the banshee because you have to buy two of everything.
i would look into a 250r or a blaster before a trailblazer myself because i`m not a fan of the cvt trannies....i like to shift.
Old Apr 17, 2007 | 08:53 AM
Scrambler00's Avatar
i love my 2 stroke scrammy, its ok at lower speeds for me like technical trails and even working but its hard on the belt for sure! the polaris oil injection keeps it very simple and reliable it uses hardly any oil, if your looking for a little 2 stroke the blasters are wicked fun and fairly reliable
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
NatePerz
Jul 27, 2015 03:27 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Jul 7, 2015 11:00 PM
