Problem
Old Apr 20, 2007 | 09:53 PM
TheBomb650's Avatar
Default Problem
I was out riding tonight and after an hour or so it started to spit and spudder. So I stopped and checked it out every thing looked and seemed fine. So, I take off again in every gear it spit and spudder when it gets up to so many rpm's. After I let it sit for a while and take off again it doesn?t start until I hit 4th gear. Did something get in the carb? Any Ideas???
Old Apr 20, 2007 | 11:21 PM
DSRIDER650X's Avatar
Default Problem
have you tried to start the quad again? That is pretty much what mine started doing. then when I went back out an hour later, it was dead!!! The battery that is. Could be the carb, but could be electrical as well.
Old Apr 20, 2007 | 11:23 PM
TheBomb650's Avatar
Default Problem
Yes I have and the same thing happends. I will take the carb apart on sunday hopefully...
Old Apr 21, 2007 | 11:28 PM
bombrider04's Avatar
Default Problem
Check your jets and make sure you can see light through them and also check for a fully charged battery, but one thing with the ds's that has been a known problem is the ventling coming from the gas tank...It is about a mile long and gets kinked sometimes and causes the quad to sputter(it is under the tank plastics)...Also make sure you have enough gas and the choke isn't on...Also do you currently have any mods?
Old Apr 22, 2007 | 01:00 AM
NickDS650's Avatar
Default Problem
Make sure ur air boot isnt collapsing, if ur hittin so many rpms and then it is sputtering ur engine could be sucking ur air tube up and that'll cut ur air supply, they made the DS's in '03 to come with a stronger tube for this problem, Mine was doin it when i got the TM45 carb and after like 4500 rpms it would dog on me, was the air tube and a slight jettin issue
Old Apr 22, 2007 | 10:38 AM
TheBomb650's Avatar
Default Problem
Nope its all stock sad to say. I hopfully will get a chance to look at it today.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
